engine hot A/C off light comes on?
110 MILES • 4 CYL • 2WD • AUTOMATIC
LUIS SANCHEZ JR.
I had a overheating engine. I recently changed my radiator fan assembly kit. And now my the needle for the engine temperature is completely cold. Also, the check engine like came on. I looked online believe that it is the thermostat that needs to be changed. I never got the chance to change it. On my way home from work the needle went back to normal the engine hot A/C off signal was no longer there, but the check engine light was still on. What do I do?
Jun 25, 2018 at 10:55 AM
  • 55,746 POSTS
It sound like the system is relearning I would clear the codes and see what happens. It is not overheating anymore right?
Here is a guide:
https://www.2carpros.com/articles/check-engine-light-clear-codes
Cheers, Ken
Sep 19, 2020 at 6:58 AM
LUIS SANCHEZ JR.
No it was fixed with replacing the fans. So no more overheating. Should I changed the thermostat just in case?
  • 55,746 POSTS
Yes, I would. Here is a guide and diagrams on how to do the job:
Check out the thermostat diagrams (below). Please let us know what happens. It shows a v6 in this car.
Cheers, Ken
