The second image is the water outlet. You looking to replace that or for gaskets?
Feb 15, 2020 at 1:08 PM
ANGEL0324
MEMBER
I need the assembly because the threads of the pulley bolt are broken.
Feb 15, 2020 at 1:11 PM
JIS001
✓Experienced Mechanic
Which pulley bolt?
Feb 15, 2020 at 1:17 PM
ANGEL0324
MEMBER
The idler pulley.
Image (Click to enlarge)
Feb 15, 2020 at 1:21 PM
JIS001
Okay, I think I see it now on the white arrow. That is the water outlet pipe.
Feb 15, 2020 at 2:03 PM
ANGEL0324
MEMBER
Yes, I have to replace that, right?
Feb 15, 2020 at 2:18 PM
JIS001
If that is where the pulley goes then yes.
Feb 15, 2020 at 2:53 PM
STEVE W.
If you mean the threads in the hole are stripped it is possible to repair that part using a thread repair kit like a heli-coil or a threadsert type insert. A heli-coil would likely be the easier of the two as it would remove less of the material.
