I have the vehicle listed above that triggered the engine light on and it started running rough. I turned the car off and then back on, and it was running like normal.
I checked the code with one of those AutoZone $50.00 code readers, and it showed as the coil F and D weren’t working. (code p2311 and p2317) I replaced them Even though the engine was working completely fine, I did the unplug and plug test, all coils were all working, the wiring doesn’t look bad or anything, spark plugs were replaced too. I cleared the code on the ECM with the code reader and i turn off the engine light with the “put the key to on three times” method but every 100-200 miles the engine light turns on, which makes the engine run rough (literary just when the engine light turns on, I literary turn the car off and on, and it runs perfectly, smoothly, like all coils are working perfectly!). Help, I’m running out of ideas.
Thank you all in advance!
Nov 23, 2020 at 12:36 AM
