Someone removed coil, need diagram to complete job
277,003 MILES • 4.2L • 6 CYL • 2WD • AUTOMATIC
RANDY JOPLIN
Someone removed coil, need diagram to complete job.
Feb 3, 2021 at 2:03 AM
SEVAG P
  • 405 POSTS
hello,
i am sending you ignition coil connector wiring diagram which are attached below.
check the diagrams below ignition timing for coil to spark plug cables.
let us know if you need more help.
thank you.
Feb 15, 2021 at 1:52 AM
SEVAG P
  • 405 POSTS
hello,
check figures below complete engine wiring diagrams for 4.2L engine, i cut each page for 3 sections to become more clear when reading.
thank you.
