Coil spring and shock assembly installation issue?
178,000 MILES • 2.7L • V6 • 2WD • AUTOMATIC
RANDY1955
  • 71 POSTS
Trying to install rear passenger side coil spring assembly it has two dowel pins on each side but on the ones on the bottom one of them will not line up it is the same part as the old one does anyone have any experience on this. Thank you
Mar 30, 2024 at 11:38 PM
  • 55,694 POSTS
It sounds like you may have the wrong part. Can you please upload an image of the problem? Here is an expanded view of the strut assembly and how to replace the rear struts and coils. Check out the images (below). Please upload pictures or videos in your response to the problem so we can see what's going on.
Mar 31, 2024 at 12:21 PM
  • 55,694 POSTS
anything?
May 11, 2024 at 6:05 AM
