trying to replace the coil spring?
100,000 MILES • 3.0L • V6 • 2WD • AUTOMATIC
SKOOTER28
  • 98 POSTS
I’m trying to replace the coil spring, and the book says to cover the first hole and the second one not visible. what does that mean?
May 22, 2025 at 4:45 AM
  • 55,845 POSTS
So this is telling you how to "clock" the spring when installing it. Rotate the spring so the end of the spring does not cover the hole. Check out the images (below). Let us know if you need anything else.
May 22, 2025 at 5:21 AM
SKOOTER28
  • 98 POSTS
Does the top have the same thing?
May 22, 2025 at 6:11 AM
  • 55,845 POSTS
It might have a recess in the upper cup as well. I would use a flashlight to inspect and go from there.
May 23, 2025 at 4:02 AM
