firing order
2003 HYUNDAI ELANTRA
114,000 MILES • 2.0L • 4 CYL • AUTOMATIC
BECKY BEST
Okay, so this might be a dumb question, but I had a mechanic look at my car to run some compression and electrical tests. He broke the plastic cover for the wire that goes in the coil pack but insists that it was already broken. Cannot seem to find the name for this wire online to try and find in a parts store or salvage. Please help, might be called a connector.
Thanks.
Nov 3, 2016 at 1:09 PM
HMAC300
  • 48,601 POSTS
it is the coil connector or if broken may be the coil itself picture shows whole thing unless it is the wiring leading to it. but it is part of coils. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Nov 4, 2016 at 12:14 AM
MSHONO
I need the order of spark plugs to the coil.
Jan 4, 2021 at 1:22 AM (Merged)
KHLOW2008
  • 41,814 POSTS
Firing order is 1, 3, 4, 2.
MSHONO
KHLOW2008
  • 41,814 POSTS
You are welcome. Hope you already have the problem resolved.
