Coil pack plug stuck
86,782 MILES • 5.4L • V8 • 4WD • AUTOMATIC
ALECIA PALMER
I am trying to remove the plug that goes into the coil pack. Well it is stuck. The clips broke and it will not budge. How do I get it off?
Nov 30, 2018 at 11:21 PM
Good morning,
If the clip broke, you will need a small screwdriver with a curved pick end that is small. Then you need to insert it in the end by the coil and pry up the lock to release.
You should replace the pigtail for the coil.
Dec 1, 2018 at 12:39 AM
