After replacing the coil pack, it will not start
214 MILES • 4.6L • V8 • 2WD • AUTOMATIC
SCOTT DALTON
I changed the coil pack and now it won't start. It acts like the battery has drained. It is not getting power. When I first changed it started clicking from the fuse box under the hood. Was I supposed to disconnect the battery before I change the coil pack?
Jul 9, 2022 at 5:52 AM
  • 55,721 POSTS
It sounds like the battery has drained, but to be sure this guide can help you test the battery with no equipment. Run down this guide and get back to us:
Jul 10, 2022 at 5:36 AM
