had hooked up the battery backwards now it will not start. trying to get spark while checking coil wires, I have two going to the coil on one plug one wire is hot and the other has no power. when I hook up the plug to the coil both become hot as I see it on the manual one is positive and the other is negative. do I have a bad coil?
Mar 13, 2017 at 7:54 AM
