Codes P0122, P0304, and P0122?
165,000 MILES • 2.4L • 4 CYL • 2WD • MANUAL
SHLBTWD
  • 34 POSTS
P0122.
P0304.
P0122.
Aug 8, 2023 at 5:47 PM
BORIS K
  • 836 POSTS
P0122 - Throttle position sensor (TPS) "A " circuit.
P0304 - Misfire cylinder 4.
These 2 codes do not seem to be related to each other.
P0122
I would suggest first checking the TPS connector. Ensure that there is no corrosion, and the pins are in good condition. The TPS is located on the side of the throttle body, image 1.
It has a 3-wire connector.
Pin 1, blue wire TPS signal back to PCM pin D14.
Pin 2, pink wire 5V power supply.
Pin 3, black wire ground/low reference.
Using a voltmeter, you can check 5V supply and ground, also check signal wire back to PCM.
How to use a voltmeter:
How to check wiring:
P0304 - misfire cylinder 4.
This is the cylinder closest to the transmission side.
How to check:
https://www.2carpros.com/articles/symptoms-of-engine-misfires-a-step-by-step-guide
and
Cheers, Boris
Aug 8, 2023 at 9:10 PM
