Codes po700 and po730
136,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
GLENN HITT
What does these codes mean? how can I fix it codes po700 and po730?
Jun 18, 2017 at 6:03 AM
HMAC300
  • 48,601 POSTS
the transmission module is having a problem sending to engine module which can be a bad PCM and 730 is show in picture for causes which may be related to the other problem. there is a recall on the PCM which yours may be included the number is H33 call dealer and give your VIN number to see if yours is on it.
Jun 18, 2017 at 7:11 AM
