CODES PO137, PO171 and now PO103
98,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
HOOKIE
  • 95 POSTS
Hello TY
you have helped me out in the past..the Po137 (bad downstream lower 02 sensor..no voltage) and Po171 bad downstream )2 sensor heater...do I have to repair these first or will these cause a PO103 code? The Po103 code is for HIGH CIRCUIT-A MASS FLOW SENSOR). I know how to prepalce the mass flow sensor, but wondering if the other codes are causing it to show a PO103??
I cleaned the mass flow sensor with MAF spray and made sure all the clamps and air filter was changed...I will see in a few days is the code shows at the auto store. I never got to check for continuity as u told me to do so between 02 connector and ECU 88 pin connector as I had knee surgery and can't work on car right now.
The PO103 is causing the car to almost stall at idle and running rough..any help MUCH appreciated..i don't want to buy the mass flow part of i don't have to..the downstream sensor was replaced 2x and stillshows both )2 error codes..must be wire problem as u said. or corroded pin at ECU or ground..please help asap..thanks!
Aug 28, 2014 at 12:51 AM
HMAC300
  • 48,601 POSTS
those are all separate codes check fuses underhood and fuel pressure with a gauge autoparts rent it.
Aug 28, 2014 at 2:29 AM
MAXIMILIAM
  • 436 POSTS
BOTH FUSES (o2) fuses are getting the correct voltage..NO other fuses are blown and fuel pump relay was swapped out with another under fuse box with same part #..still same problems..
I am sorry but the codes were PO103 (mass flow air), Po141=Heater, downstream 02 sensor, and PO137= low volatge downstream 02 sensor)..my mian queation is does a bad mass flow sensor cause the other codes? please check w/ TY as he is familiar with this problem as he emailed me several times in regard to this..MANY THANKS
1998 KIA SPORTAGE 2.0 liter, automatic
Aug 28, 2014 at 4:03 PM
HOOKIE
  • 95 POSTS
MAX DID NOT SEE any response from you, yet I got an email saying you posted one to me??
hookie
Aug 29, 2014 at 12:14 AM
