Codes P2001 and P202E-8
201,334 MILES • 3.2L • V6 • 2WD • AUTOMATIC
MB-POWER
  • 80 POSTS
This car have no acceleration more than 2000 rpm's. Throttle body and throttle pedal has been replaced with used. same problem continued!
Any advice please.
Thanks
Nov 10, 2017 at 6:51 PM
More than likely there is an issue with the P202E code which is for the throttle control.
However, this guide will help with getting us started on this issue:
https://www.2carpros.com/articles/engine-has-low-power-output
I am going to attach the info below on how to test these codes but I would focus on the P202E code and see what turn up on the testing.
Please run through this and let us know what you find. Thanks
Sep 14, 2021 at 12:06 PM
MB-POWER
  • 80 POSTS
ECU has been replaced with used one and it's okay now.
Thanks for every body.
