Codes p052c and p0021?
84,000 MILES • V6 • 2WD • AUTOMATIC
BHAMDOC1973
  • 2,007 POSTS
no funny noises, drives great.
Nov 13, 2022 at 3:44 AM
  • 110,248 POSTS
The first code, P052C indicates the bank 2 intake camshaft is showing the timing as advanced too far during cold start. The other code, P0021, indicates the same information but differs because it is not only related to a cold start.
This could be a few things. First, the camshaft sensor may be failing. Also, you could try having the sensor adaptation relearned.
Keep in mind, this could be a stretched timing chain, but that is hard to believe at this mileage.
Is this something you plan to repair yourself? The sensor may not be too bad, but the sensor adaptation will require specialized tooling.
Nov 13, 2022 at 10:00 AM
BHAMDOC1973
  • 2,007 POSTS
Yes, I plan on fixing it myself. I have severe scan tools as well as entry if needed, if I know how to perform the adaptation I would do it.
Nov 13, 2022 at 10:01 AM
  • 110,248 POSTS
Great. If you can, let me know how things turn out for you or if you have other questions.
Nov 13, 2022 at 11:26 AM
