I know these are O2 sensors. Are they the same part in two different locations along the exhaust? I provided images of the obdII readouts.
Images (Click to enlarge)
Mar 8, 2023 at 4:18 AM
✓Experienced Mechanic
The codes you have for sensor 1 on both banks (1 and 2). See pic 1 below for locations.
According to the part numbers, they are both air/fuel mixture sensors, and they have the same part number. See pic 2.
Mar 8, 2023 at 12:52 PM
BRUX
MEMBER
Yes, very helpful. Thank you, Joe. I hadn't really thought of the engine as it is depicted in that diagram either.
Mar 8, 2023 at 1:06 PM
No problem whatsoever. Let me know if there is anything I can do to help or if you have questions.
Mar 8, 2023 at 1:39 PM
BRUX
MEMBER
Just noticed that the part numbers are almost identical. I'm not sure if this is an important observation, or if I understand what I am seeing.
In the image, I've underlined the discrepancy in red.
Image (Click to enlarge)
Mar 8, 2023 at 4:26 PM
BRUX
MEMBER
I'm guessing that if there is a difference, it would be in the length of the connector lead and possibly to the connector head itself.
Mar 8, 2023 at 4:32 PM
I agree. Let me know how things turn out for you or if you have other questions.
