Codes P0036 P1450
2016 FORD EDGE
123,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
MJTHOMPSON
My edge will have a vibration type sound towards the rear off and on with a couple seconds in between. If I come to a stop the engine will stall. I also have to shut off the engine to put fuel in it or it will lag down and idle harsh as it fuels up if it doesn’t shut off completely. I have purchased a terminal vent valve part# 911-216 and I believe it is located in the rear on the drive side midways. I’m just curious if this will fix either code?
Sep 7, 2021 at 3:30 PM
