Codes OBD1 et OBD2?
117,000 MILES • 2.5L • 4WD • AUTOMATIC
PAPACASTOR
Une batterie 12V faible peut-elle faire déclencher des codes OBD1 et OBD2 ?
KILOMETRES 117,000
Nov 7, 2026 at 11:21 PM
STEVE W.
  • 15,401 POSTS
It could but it would depend on what the code is. There are some that are low voltage codes but a low battery can cause some strange issues as well. A 2017 would be OBDII codes with suffixes in many cases. OBDI existed prior to 1995 in the US, other countries had them a little longer but pretty much everyone was OBDII by the time 2000 rolled around. Unless it is a vehicle that was never exported in a different country.
Nov 8, 2026 at 8:33 AM
