codes
250,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
DISMAL8
check engine light on checked code it has thirty one codes. what happened?
Sep 4, 2017 at 9:01 PM
STEVE W.
  • 15,421 POSTS
Without knowing the exact codes and what the vehicles symptoms are we cannot answer that question. It could be anything from a blown fuse shutting off parts of the PCM to shorted wiring or rodent damaged wiring.
Please list the codes and symptoms and we can try to assist you.
Sep 5, 2017 at 8:21 PM
DISMAL8
I will have go back to Advance Auto to get scan again but the most of the code were for the power train.
will send as soon as possible. thanks for your help.
Dane
Sep 5, 2017 at 8:42 PM
  • 55,782 POSTS
I good way to approach this problem is to clean all codes then without starting the engine turn the ignition key on and read the codes. If all codes are present then it sounds like the PCM has gone out. You in Texas by any chance?
Here is a guide to help you read the codes, codes readers are cheap nowadays:
If the engine computer is bad (PCM) I would try to find a used one that way it will be plug and play.
(Location below)
Cheers, Ken
Sep 7, 2017 at 3:00 AM
