Codes $7E8 an $7E9
154,440 MILES • 5.7L • V8 • 2WD • AUTOMATIC
JOHNNY EUDY
  • 6 POSTS
What are the codes? I was driving an engine light came on an checked it an codes $7E8 an $7E9 popped up. what are the codes for?
Jan 21, 2019 at 9:39 PM
Good morning,
These are CAN codes so you have a PCM or BCM that is not working but I have seen these cars needing a TIPM which is easy to replace because it self initializes.
This video will help
https://youtu.be/InIlnsjOVFA
Jan 21, 2019 at 10:00 PM
JOHNNY EUDY
  • 6 POSTS
I did recheck it an code was exactly like this $7E8 an $7E9 an that all it showed.
Jan 21, 2019 at 11:20 PM
What kind of a scan tool are you using?
This guide will help
Can you upload a picture of the screen? Roy
Jan 21, 2019 at 11:25 PM
JOHNNY EUDY
  • 6 POSTS
This is the scanner i am using.
Jan 21, 2019 at 11:42 PM
JOHNNY EUDY
  • 6 POSTS
Yea i know. everything seemed to shift and drive fine so i reset them. but i will take a picture next time. Thank you for you assistance .
Jan 22, 2019 at 12:05 AM
You are welcome.
always glad to help.
Jan 22, 2019 at 12:10 AM
JOHNNY EUDY
  • 6 POSTS
Okay this was the codes.
Jan 22, 2019 at 12:14 AM
It says 1 of 3. I only see 2.
You need to go to a parts store and have them read it in the correct format.
Jan 22, 2019 at 12:17 AM
JOHNNY EUDY
  • 6 POSTS
Yea, the third part is the previous menu when you scroll down number 3 is on previous menu only 2 codes.
Jan 22, 2019 at 12:22 AM
Okay, got it.
Jan 22, 2019 at 12:31 AM
CARMELOLES
I have the same issue got a new TIPM fix it for me. Cleared the codes have not come back.
Dec 1, 2019 at 2:28 PM
Nice work, we are here to help, please use 2CarPros anytime.
Dec 1, 2019 at 9:07 PM
Just in case others have questions on this. This is a pretty common issue on these vehicles. TIPM stands for Totally Integrated Power Module, but this vehicle does not have a TIPM. It has an IPM Integrated Power Module. Slightly different but basically does the same thing.
These codes are very common but they are actually a generic scan tool issue on not being able to read the actual codes that are there.
The most common correction of this is a TIPM or IPM as the circuit boards fail and cause all sorts of different issues. It is very common.
I attached the process below for more info on how to replace it.
Sep 3, 2021 at 10:37 AM
