codes
142,000 MILES • 4.6L • 2WD • AUTOMATIC
CROWNVIC1993
I ran codes on my car listed above.
koeo = 111
koeo continuous code 332 insufficient EGR
flow.
koer = 111
Why did 332 not show in the koer test?
Thanks for your help.
Jan 29, 2018 at 1:49 AM
The EGR is not tested with the key on engine off. it is only tested when the engine is running.
Jan 30, 2018 at 1:53 AM
CROWNVIC1993
In the code book it says that code 332 test condition R,C (running/continuous). I expected to see 332 when koer since it showed in the continuous code, but it did not. why did it not show in koer?
Jan 30, 2018 at 9:35 PM
the fault was not at that time the test was running. it was active at some point but not when the test ran.
Jan 30, 2018 at 9:38 PM
