Codes
55,000 MILES • 2.4L • 4 CYL • 2WD • MANUAL
VICTORY76
  • 27 POSTS
After an accident, the ABS wiring, and ABS pump was damaged someone got a new harness wiring from a Honda dealer cut off part of the wiring needed, and made up the new connection, after that a lot of codes came out the vehicle was brought to me. I discovered some wires in the wrong place after soldering and put back all together SVA and TPMS and Airbag came out to the dashboard car run well, the tool on the steering wheel allow to relearn the TPMS, but after that came back immediately.
Mar 10, 2022 at 10:05 AM
  • 110,248 POSTS
It sounds like there are still wiring issues. What codes are presently stored? Also, I don't know if you have them, but I attached the wiring schematics for the ABS system.
Take a look through the schematics to confirm nothing was mixed up. Also, the schematic is for a non-hybrid sedan. If that is wrong, let me know.
Take care and let me know.
See pics below. Note: The schematic was only one page, but I had to cut it in half to make it readable for you. Also, I did overlap the two pics so you can follow from one to the next.
Mar 11, 2022 at 6:36 AM
VICTORY76
  • 27 POSTS
Thanks so much, I will double-check, now just I'm guessing the wiring to the ABS will be not the right one anyway I will try my best I will let you know have a great weekend.
Mar 12, 2022 at 7:06 AM
  • 110,248 POSTS
You are very welcome. Let me know if there is anything I can do to help.
Mar 12, 2022 at 8:08 AM
