What do these codes mean, 1765, 0753, 1740?
130,000 MILES • 5.9L • V8 • 4WD • AUTOMATIC
RACHEL WINDHAM
Codes.
Oct 22, 2022 at 10:02 AM
  • 110,248 POSTS
All of the codes are transmission related. I attached a definition below for each one.
I'm not sure what symptoms you are experiencing, but the first thing I would suspect is there is a voltage issue. Have you had any issues with the battery or alternator? If not, it could be a corrosion issue or damaged wire going to the transmission.
Take a look through the pics below. Let me know if that is what you were looking for.
Oct 23, 2022 at 11:08 AM
