Codes 120308 and 118001?
170,000 MILES • 2.0L • 4 CYL • TURBO • 4WD • AUTOMATIC
ASHOK SAINI
  • 32 POSTS
I have been struggling alone for 1 year to fix these codes. II had an engine change. I have resolved 120308 Charge air pressure too low by sealing all the connections making them air tight. I didn't change the seals but applied gasket maker everywhere which sealed everything, like intercooler pipe intake air, throttle seal area, breather pipe. But i am still getting 118001 fuel air mixture too lean. I get code 120308 off and on and also sometimes while taking turn my transmission malfunction kicks in. Very confused, please advise..
Jul 14, 2023 at 12:59 PM
  • 55,743 POSTS
The error codes you provided are associated with BMW vehicles. Here's some information about each code:
120308: This code corresponds to the "Valvetronic eccentric shaft sensor guide" on a BMW.
118001: This code is related to the "Mass or Volume Air Flow 'A' Circuit Range/Performance" on a BMW.
So, I would make sure the air intake is in good shape with no cracks, if there were no leaks I would change out the MAF sensor and then clear the codes. Check out the images (below). Please let us know how it goes.
Jul 15, 2023 at 4:32 AM
ASHOK SAINI
  • 32 POSTS
Thanks for getting back to me. My vehicle is BMW X3 2013 2.0 turbo N20 engine but your reference is related to N54.
Jul 16, 2023 at 2:47 AM
  • 55,743 POSTS
My bad, sorry, here is the correct information. Check out the images (below). Please let us know what happens.
Jul 17, 2023 at 2:54 AM
