I went to have my vehicle scanned because of my "Engine" light. It appears I have 2 codes P0136 and P0141. P0141 says check the circuit fuse. Unfortunately I do not know where that fuse is located. I know where the box is located, but I do not have a diagram.. P0136 says vehicle is running very rich or lean. Either way my fuel is disappearing very fast and gas is too high.. Is there a way to fix this problem..
PS. I know there other explanations for the problems. I just used one example for each.
Thank you
Thank you
Apr 28, 2013 at 12:43 AM
