Code p1593 speed control sensor
122,000 MILES • 2.0L • 4 CYL
JOHNDOUGLAS69
Trying to locate speed control sensor code P1593.
Jul 6, 2020 at 5:23 AM
STEVE W.
  • 15,418 POSTS
Code P1593 isn't a sensor it refers to the speed control switch on the steering wheel. However it could be a bad switch, bad clock-spring, bad harness or bad control module. To test you have to remove the air bag module from the steering wheel then remove the steering wheel, then the clock-spring and finally unplug the switch, then use a scan tool and test to see if the correct voltages are present on the wiring coming through the plug. Without a factory scan tool you would be very limited to testing and likely would only be able to change out the switch and hope it was the problem.
Jul 6, 2020 at 6:06 AM
HAVAS BORES
How do i order for 1978 chevy caprice th350 with cruise control.
Jul 7, 2020 at 1:54 AM
STEVE W.
  • 15,418 POSTS
HAVAS BORES Could you please use this link and ask this as a new question, please specify what it is you are trying to find as well, thank you.
Jul 7, 2020 at 7:12 AM
