Code u1102
120,000 MILES • 3.0L • 6 CYL • 4WD • AUTOMATIC
CHEFANTHONY6914
I have a Pajero 2010. it stops in the middle of the road and coolant temperature light glows for like 5 seconds and this happens everyday while i am coming from work evening. when i diagnose this code occur U1102, what does it mean? I need help why the car stops.
Aug 25, 2019 at 4:10 AM
  • 110,251 POSTS
Welcome to 2CarPros.
First, this specific model Mitsubishi isn't offered in the US, so my technical information is very limited. However, I can tell you there is an issue between ASTC and ECU. ASTC is the active stability and traction control. The ECU is the electronic control unit.
Between these two components, there is a power issue. The most common causes include the following:
Damaged wiring harness or connector
Automatic Transmission control module failed
Failed ASTC - ECU
_______________________________
Let me know if that helps. I could normally go further, but I have no wiring schematics for this specific vehicle.
Aug 26, 2019 at 11:21 AM
CHEFANTHONY6914
Thanks Joe at least you try to help me appreciated ,but how can i check this
Failed ASTC - ECU
or i was thinking that the issue is with SCV (suction Control Valve ) please write to me if you can help
thanks in advance
Aug 28, 2019 at 5:02 AM
  • 110,251 POSTS
Welcome back:
You are very welcome. I just hope I can.
After reading through the manual, the plug is what seems to be the most common cause of is a bad connection. Check the connector for corrosion or a damaged pin. Also, take a look at the wiring to make sure the insulation isn't damaged.
Aug 28, 2019 at 10:16 AM
