code reader is reading $7e8 engine and $7e9 a/t
58,000 MILES • V8 • 2WD • AUTOMATIC
LAMBYKINS
the check engine light came on. Did not appear to be having any problems. this happened after a hard acceleration.
Jan 31, 2021 at 8:36 AM
  • 110,248 POSTS
What codes have been retrieved? What you listed in the heading aren't codes.
Here is a video that shows how to retrieve codes:
https://youtu.be/b2IJGfImVvw
Also, are there any driveability issues?
Let me know what you find.
Take care and God bless,
Jan 31, 2021 at 11:18 AM
LAMBYKINS
those are codes.They showed up on my code reader. could they be jagyar specific? I didn't notice any driveability issues. Help me out here plaese. thank you , Lambykins
Feb 2, 2021 at 3:10 PM
  • 110,248 POSTS
They could be manufacturer specific. I have no listing for them. Is it possible for you to get the P codes?
Feb 3, 2021 at 7:55 AM
Just to weigh in on this. These are codes that are typically pulled up from an aftermarket code reader on these higher line products. These codes are not trouble codes but instead just informational.
The E8 means the engine control module was interrogated for codes. The E9 means the Transmission control module was asked for codes as well.
If these are the only codes that you have then there are no issues with the vehicle that would set a code.
Hope this helps. Thanks
Apr 9, 2022 at 2:43 AM
