Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Chevrolet
Aveo
Warning Lights
Check Engine Light
code reader
2010 CHEVROLET AVEO
86,000 MILES • 1.6L • 4 CYL • 2WD • AUTOMATIC
NOBLE GOULD
MEMBER
1 POST
Check engine light is on plugged my obd11 scanner in to check it keep showing $7E8 and red light on scanner is on.
May 29, 2020 at 11:38 AM
Experienced Mechanic
Those aren't codes. Basically, it is an indicator that specific modules are present. Go into read codes and then select. That should do it for you.
Let me know if that helps.
May 29, 2020 at 12:17 PM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Check engine light
