Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Chevrolet
Cheyenne
Engine
Symptoms
Not Running
Engine cranks but does not start
1994 CHEVROLET CHEYENNE
160,000 MILES • 4.3L • 6 CYL • 2WD • AUTOMATIC
RUDY55
MEMBER
code - quad driver module 4th gear circuit.
Apr 21, 2021 at 10:21 AM
Experienced Mechanic
Here is a guide that will help get us started:
https://youtu.be/dCjmRL3p4Cs
However, can you provide the actual code that you got out of this? If so, we can provide the testing that you need to run through to figure out what is needed.
https://www.2carpros.com/articles/buick-cadillac-chevy-gmc-oldsmobile-pontiac-gm-1983-1995-obd1-code-definitions-and-retrieval-method
Let's start with this and go from there. Thanks
Apr 22, 2021 at 11:47 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
