My check engine light came on so I had it scanned and it's showing code po300.
So I Googled the causes of code po300 and it's a random/multiple cylinder misfire. So i went trough all the possible causes of the problem .
I have already replaced the spark plugs.
I replaced the coil packs.
I replaced the EGR valve.
I replaced the crankshaft sensor.
I replaced the camshaft sensor.
I replaced the throttle positioning sensor.
I cleaned the fuel injectors.
I checked the catalytic converters which they are good.
I checked for vacuum leaks. There were none.
I dropped the gas tank and checked the fuel pump which is good.
And replaced one of the four o2 sensors .
And after all of that it still keeps throwing the code .
So if you have any idea what this is or might be the problem with it i am all ears. Lol. I can't affordably take it to a mechanic right now I was just laid off . so any suggestions that might help me.
Nov 17, 2020 at 10:23 AM
