Code po300
119,000 MILES • 4.8L • V8 • 2WD • AUTOMATIC
GLENN VAN SCYOC
Misfire, check engine light.
Mar 25, 2019 at 6:19 AM
SEVAG P
  • 405 POSTS
Hello thanks for using 2CarPros.
For the fault code p0300 misfire run our guide.
Let us know what happens.
thank you.
Mar 25, 2019 at 6:49 AM
SEVAG P
  • 405 POSTS
Misfire is a result of no proper combustion inside a cylinder that causes absence of spark, fuel or low engine compression.
Check for spark run our guide:
Check injector pulse run our guide:
https://www.2carpros.com/articles/how-to-test-a-fuel-injector
Check engine compression:
Feed back the result we are interested to know the problem.
Thank you
Mar 26, 2019 at 6:31 AM
