code po121 tps
100,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
CHARLES 123
have replaced TPS but check engine light keeps coming back on.
Aug 13, 2017 at 3:50 AM
DIESEL&AUTOTECH
  • 5 POSTS
May not be TPS. Check wiring leading up to TPS.
Aug 13, 2017 at 4:26 AM
STEVE W.
  • 15,409 POSTS
First thing is to clean the throttle body. Carbon can cause the throttle to hang and the ECM thinks this is a TPS issue because it cannot close fully.
Next is to look at the data coming from the throttle control system, for that you need a scan tool with bi-directional control. With that on there you can wiggle the harness and see if it is a bad wire/loose connection or similar. You can also watch the system to look at the voltages it is seeing from the TPS.
Aug 13, 2017 at 4:47 AM
DIESEL&AUTOTECH
  • 5 POSTS
I remember there were a lot of issues on those vehicles with wiring they were trying to push for recall. But Steve is right, clean the throttle body first and see..they may have given you a faulty sensor too. Good luck
Aug 13, 2017 at 7:56 PM
STEVE W.
  • 15,409 POSTS
Still are pushing for GM to do the replacement TBs and software updates but it is like pushing water with a rake.
Aug 14, 2017 at 1:40 AM
