The code P0012 is the intake camshaft position timing- Over-Retarded (Bank 1); so what happens is the Variable Camshaft Timing (VCT) Oil Control Solenoids can stop working but I need to ask if the engine oil is full and clean, if not change it out with a new filter, if the oil is okay here is the location of the valve so you can remove it for replacement. Bank 1 is on the driver's side of the engine. Check out the images (below). Let us know what happens and please upload pictures or videos of the problem.
Images (Click to enlarge)
Sep 10, 2022 at 4:52 AM
