Code p0480 fans only work when the car is turned off?
152,000 MILES • AUTOMATIC
MOSHNN
  • 6 POSTS
I have replaced the fan control module, a coolant temperature sensor. Now I have bridged the relay that hangs behind the front driver side light and the fans only work when the car is turned off. As soon as turn the ignition key the fans slowly stop running. what is my problem
Jul 28, 2026 at 6:42 AM
  • 55,710 POSTS
Hello, I can help you, P0480 is Cooling Fan Relay 1 Control Circuit Malfunction. It usually means the PCM doesn't see the expected electrical response when it commands the fan relay. So I would check the grounds first and return the fan relay to the stock wiring. Here is how the system is wired so you can see it avoid confusion, here is how to check the grounds which I have marked for you.
https://www.2carpros.com/articles/how-to-use-a-test-light-circuit-tester/
Check out the images (below). Let me know what you find.
Jul 28, 2026 at 6:00 PM
MOSHNN
  • 6 POSTS
Those points you indicated are grounded. It seems the pink wire coming from the cooling fan relay does not work. Is there a way to correct this.
Jul 30, 2026 at 9:45 AM
  • 55,710 POSTS
Yes, please check the fuse in the image below which is located int eh front left of the engine compartment. Please let me know.
Jul 31, 2026 at 8:24 AM
MOSHNN
  • 6 POSTS
The powertrain fuse, ecu 2, and the main relay in the fuse box all look good. I tested the main relay to see. Also the mega 60a cooling fan fuse looks good.
Jul 31, 2026 at 8:49 AM
  • 55,710 POSTS
The pink wire must have power when the car is on. If not you have a broken wire. Check out the image below.
Jul 31, 2026 at 9:09 AM
MOSHNN
  • 6 POSTS
how do I change the wire. If I remove the fuse box is it hard to figure out which wire it is.
Jul 31, 2026 at 10:54 AM
  • 55,710 POSTS
Does the ECU 2 fuse have power on both sides?
Jul 31, 2026 at 6:58 PM
MOSHNN
  • 6 POSTS
I have purchased an add a circuit wire so I could just add to the front of the box and not have to remove it from the car and try and get through the tangle of all the wires going in. I really have to thank you for your help and especially the diagram since I could not find on one online and it was what made the difference in diagnosing the problem. Will take a few days to get the wire since no one local had one that would accept a 15a fuse.
Aug 2, 2026 at 7:47 AM
  • 55,710 POSTS
You are welcome, let me know if the fuse has power on both sides.
Aug 2, 2026 at 9:03 AM
MOSHNN
  • 6 POSTS
The fuse does have power on both sides. How safe is using an add a circuit wire to the fuse box. That doesn't create any dangerous situations does it.
Aug 2, 2026 at 9:57 AM
  • 55,710 POSTS
It needs to be switch power (no with ignition switch) and be able to handle 15 amps FYI.
Aug 3, 2026 at 9:38 AM
