Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Lincoln
Mark VIII
Warning Lights
Check Engine Light
code P2C55 and PO4E0
1998 LINCOLN MARK VIII
153,000 MILES
CONNIE SELLERS
MEMBER
1 POST
came up on scanner but does not explain.
Sep 12, 2017 at 1:54 PM
Experienced Mechanic
Neither of the codes makes sense. can you try a different code reader or try it on a different car? You could have a bad PCM causing the problem.
Cheers, Ken
Sep 13, 2017 at 4:52 AM
Add image or video
Ask a new question
Engine won't start
Engine overheating
