Code p2757 has popped probably 4-5 separate times?
250,000 MILES • 1.8L • AUTOMATIC
BRENTULRICH88
  • 42 POSTS
I have code p2757. This code has popped probably 4-5 separate times for the past 7ish years. Figured I should ask on here about where to start and any advice you may have. Heard it could be couple different things.
Aug 1, 2026 at 12:50 PM
KRAKENAUTO
  • 113 POSTS
Have you ever changed your transmission fluid before this started occurring? If not, when was the last time you done so? If it has never been done I would first do that (just fluid and filter, NOT a flush). It should be replaced normally every 30-40k.
This code usually is due to dirty transmission fluid, pressure control solenoid or a wiring fault in the transmission.
Aug 1, 2026 at 1:01 PM
  • 55,711 POSTS
Hello and welcome to the site,
Here is the code definition.
P2757 – Torque Converter Clutch Pressure Control Solenoid Control Circuit Performance/Stuck Off
I would service the transmission first drain and fill the fluid, here is a guide to help you and the instructions for your car in the images below.
https://2carpros.com/articles/how-to-service-an-automatic-transmission/
Equivalent fluids that specifically state they meet the Toyota WS specification include:
Toyota Genuine ATF WS (best choice)
Valvoline Import Multi-Vehicle ATF (WS compatible)
Castrol Transmax Import Multi-Vehicle ATF (WS compatible)
Idemitsu ATF Type TLS-LV (WS compatible)
Drain and refill: Approximately 2.5–3.5 quarts (depends on how much drains out).
Clear the codes once completed. Check out the images (below). Let me know how it goes
Aug 1, 2026 at 1:09 PM
