Code P20b9 and “service exhaust system” warning on
42,000 MILES • 6.6L • V8 • TURBO • 4WD • AUTOMATIC
CHARLIE1229
  • 46 POSTS
Will installing a new DEF heater resolve this issue or is there other steps I should look into first?
Nov 7, 2019 at 11:28 AM
  • 110,248 POSTS
Hi:
I believe that code is related to the DEF system running it's own self test and not the heater. Try this. An onboard test must be commanded using a scan tool. A fluid quality test or a forced REGEN will make the monitor run and the messages should clear and the system should return to normal. Basically, you need to force a fluid quality test using a scan tool.
Try this and let me know if it helps.
Nov 8, 2019 at 10:15 AM
