Code P1780
325,000 MILES • 3.4L • V6 • 4WD • AUTOMATIC
DANO1971
  • 32 POSTS
I took my car for emissions test the other day and it failed with a code p1780. The car starts the only problem with that at all. I ordered a new neutral safety switch I am going to replace that today. How can I tell before I start this if that is the problem ? It is an older car and I am sure it has not been replaced in a long time and there is a lot of play in the gear shifter. Any kind of help would be appreciated. thank you.
Jul 4, 2017 at 11:51 PM
DANO1971
  • 32 POSTS
On that last post I meant to put I have no problem with starting car. Also, do I need to have the car in park or in neutral safety switch?
Jul 5, 2017 at 1:24 AM
  • 55,732 POSTS
When replacing the switch have the car in neutral. Here are a couple of guides that will help you get the job done.
https://www.2carpros.com/articles/how-a-neutral-safety-switch-works
and
Cheers, Ken
Jul 7, 2017 at 5:03 AM
DANO1971
  • 32 POSTS
Thanks for the help. I just got done taking off the NSS. Cleaning everything up inside of the plug and the outside of it.
Jul 8, 2017 at 3:50 AM
DANO1971
  • 32 POSTS
Pu5 the new switch in. It's running better, it's shifting better, and the check engine light went out. I just hope it stays out.
Jul 8, 2017 at 5:06 AM
  • 55,732 POSTS
Good to hear, please use 2CarPros anytime we are here to help.
Cheers, Ken
Jul 8, 2017 at 12:47 PM
WANGNNFNN
What does a toyota obd code p1780 mean?
Jul 8, 2017 at 12:48 PM (Merged)
  • 110,248 POSTS
P1780
Park/Neutral Position Switch Malfunction
That is for an automatic trans only.
JINING
the park neutral safety switch is malfunctioning
It means you should replace your gas pedal immediately!
