Code P1572
130,000 MILES • 0.5L • V8 • 2WD • AUTOMATIC
COOLJOJOZA
Car runs good until it warms up. it has code P1572.
Jul 27, 2016 at 4:16 AM
AL514
  • 5,700 POSTS
DTC code P1572 is brake pedal switch circuit malfunction.
Jul 27, 2016 at 4:21 AM
COOLJOJOZA
I put a new one on. I know it has two, but will code P1572 cause it to run bad and shut off?
Jul 27, 2016 at 4:48 AM
HMAC300
  • 48,601 POSTS
it is a brake switch problem, but it also goes to the PCM so check for a shorted wire it is orange/yellow wire pin 25 on PCM. also check fuel pressure with a gauge auto parts rent it. and clean throttle plate on both sides and iac hole with choke cleaner.
Jul 27, 2016 at 5:29 AM
