code p1521, oes this code really usually indicate the wrong type of oil or dirty oil?
140,000 MILES • V8
DIVIDES
  • 903 POSTS
Hemi engine. Does this code really usually indicate the wrong type of oil or dirty oil?
Nov 7, 2021 at 6:52 AM
  • 110,251 POSTS
Absolutely, it does. It could be the viscosity is incorrect, the wrong type of oil, or excessive dirt. Any of the aforementioned conditions can create a problem with the multi-displacement system (MDS). The MDS is designed to deactivate certain cylinders when power isn't needed. As a result, it improves efficiency.
Below are the diagnostics and description of the code.
I hope this helps. Let me know if you have other questions.
Nov 7, 2021 at 1:45 PM
