Code p1259 non v-tech engine
161,859 MILES • 1.8L • 4 CYL • 2WD • AUTOMATIC
BCMULLEN95
  • 249 POSTS
I need assistance in figuring what the problem is with my car. Has code p1259 low oil pressure. The car is a non v-tech.
Nov 11, 2020 at 12:49 AM
Has this had an engine swap or anything else? The reason I ask, is this code is specific to the VTEC system. Or has the PCM been replaced?
Clearly the code and the non v-tec engine do not add up. In fact when you select the non vtec engine, they don't even populate the code as it is not a valid code for that engine. So if you truly a non vtec engine and this code then we have something swapped. Thanks
Nov 11, 2020 at 1:56 AM
BCMULLEN95
  • 249 POSTS
I have no Idea, my daughter purchased it and this was one of the codes. Guess I will be doing a computer swap.
Dec 15, 2020 at 5:18 AM
BCMULLEN95
  • 249 POSTS
This car does not have the wiring for a v-tech, so the computer was probably replaced.
Dec 15, 2020 at 5:19 AM
Yeah. Based on this information, I would have to agree. I don't see another reason for getting this code. I also, don't see a difference between the PCMs so I guess it is possible to swap a VTEC for non VTEC PCM. I have never compared them so I am not sure the plugs are the same but it would make sense that they are as the software would be the only thing that needs to be different.
Dec 16, 2020 at 8:45 AM
