Codes P0705 and P0685, automatic transmission problem car does not move?
60,000 MILES • 3.0L • 6 CYL • 2WD • AUTOMATIC
BOB JO
Hi, I changed Automatic Transmission and the car start engine but don't move on D or R directly engine off.
Please i need help !
Jun 25, 2024 at 5:07 AM
  • 55,851 POSTS
So, with these codes it can make it so the transmission will not work, especially the first code.
P0705 - Transmission Range Sensor Circuit Malfunction (PRNDL Input)
P0685 - ECM/PCM Power Relay Control Circuit /Open
The first thing I would do is make sure the system grounds are connected and the gear range sensor is plugged in, here is the location so you can check it out. Check out the images (below). Please let us know what happens.
Jun 25, 2024 at 6:57 AM
BOB JO
Thanks for your answer, i changed the Transmission Range Sensor but the problem still. When i checked the oil in AT i don't found oil!!!
Is that the main problem?
I put 4ltr mobis oil IV , but still problem !
Jun 25, 2024 at 10:36 AM
  • 55,851 POSTS
Yep, then need fluid to work, do you have the correct fluid level now? Also did you clear the codes after replacing the neutral safety switch? Also, can you double check to make sure the CV axles are plugged into the transaxle completely?
Jun 26, 2024 at 3:10 AM
BOB JO
Hey, first question, now the level correct. Second question, I cleared the codes now the OBD check no codes. Third question, the CV axles plugged completely. But the problem is still when i turn on the engine and try to drive on D or R the eng forced off.
But now after put oil to AT the car better than before. When turn on and off eng more than once time the AT working. But when i turn off eng the problem came again !!!!!!
Jun 26, 2024 at 5:45 AM
  • 55,851 POSTS
It sounds like the torque converter has fallen apart internally. But we can try the replace the valve body solenoids to see if that helps. Can you upload a short video of what the problem is? Check out the images (below). Please let us know what happens.
Jun 27, 2024 at 2:56 AM
BOB JO
Thanks for your help, when i replace AT i put a used AT from the garage, so now i have returned the AT and replaced another one. Now the car is normally by the second AT. Thank you again.
Jul 7, 2024 at 6:13 AM
  • 55,851 POSTS
Good to hear, you must have gotten a defective unit the first time. Thanks for letting us know, we are here to help, please use 2CarPros anytime.
Jul 8, 2024 at 2:49 AM
