Code p0701
152,000 MILES • 3.0L • V6 • 4WD • AUTOMATIC
MICHAELS789
  • 5 POSTS
Idles fine, will not drive when transmission in gear.
Nov 25, 2017 at 5:20 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
That code refers to the fact that there is another code stored in the transmission control module.
Also, you should check the two fuses that supply the transmission control module with power, the fuses #F1.15 and F1.48 both in the battery junction block.
Nov 25, 2017 at 6:03 AM
MICHAELS789
  • 5 POSTS
Okay, I will check fuses and get back to you.
Thank you!
Nov 25, 2017 at 7:24 AM
MICHAELS789
  • 5 POSTS
Okay, I checked those fuses and they are good. Now what? I really need help getting this figured out ASAP.
Nov 25, 2017 at 8:40 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
Do you have a scan tool capable of reading codes from the transmission control module? If you are using a simple code reader it most likely cannot read those codes and your next step would be to get the codes from the TCM. Once you give those codes or code to me I could get you a troubleshooting procedure.
Nov 25, 2017 at 11:02 PM
MICHAELS789
  • 5 POSTS
I do not have that kind of scanner, and I am unable to get the car to a place to have it checked. is the another way?
Nov 26, 2017 at 1:13 AM
MICHAELS789
  • 5 POSTS
Will the VIN number help? Please let me know. Here it is: VIN number 1FMDK06186GA28359.
Nov 26, 2017 at 1:15 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
You may have to end up having it towed and most likely to the dealer in order to retrieve that code and proceed.
Nov 26, 2017 at 2:47 AM
