Hi, just want to know where to start a troubleshooting, i got a code P0685 PCM/ECM power relay control circuit/open.
Apr 3, 2021 at 2:09 AM
✓Experienced Mechanic
Good afternoon,
Does the check engine light come on with the key on? If the light comes on, then most likely you have power to the ECM. I attached the connector diagram for you to view to verify power to the ECM.
Yes, the check engine light comes on with the key on.
Apr 4, 2021 at 1:40 PM
Okay, then most likely the ECM has failed since the light comes on and you can communicate with it.
Apr 4, 2021 at 8:35 PM
MARK87
MEMBER
At times the radio would just switch off and come back on. once it happen the car just shut down, but started after a while. Could it be a bad relay or blown fuse?
Apr 5, 2021 at 10:13 PM
Site rules are one issue per question. If you start a new question, I would be happy to help you with the radio issue.
