Code p0641, causing reduced engine power?
220,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
DSMITTY1290
  • 6 POSTS
I keep getting a code p0641 with reduced engine power it's intermittent so it's hard to troubleshoot. plus, I don't really know where to start. thanks in advance.
Sep 13, 2023 at 9:33 PM
  • 55,710 POSTS
So, this code can happen when the PCM goes out or you have a sensor that is shorted causing the PCM to dump voltage. I would remove the camshaft potions wiring connector and use a voltmeter to check the voltage at terminal A in the connector, it should be 5 volts. If not, start unplugging the remainder of the sensors one at a time until you see the voltage return, this will be the shorted unit causing the problem.
The OBD-II trouble code P0641 in a 2008 Chevrolet HHR indicates a problem with the "5-Volt Reference 1 Circuit."
Here are the engine wiring diagrams so you can see the sensors involved that must be unplugged from the system. Check out the images (below). Let us know what happens and please upload pictures or videos of the problem so we can see what's going on.
Sep 14, 2023 at 4:48 AM
DSMITTY1290
  • 6 POSTS
Thank you so much. I'll start testing sensors right away and I will let you know.
Sep 14, 2023 at 5:51 AM
DSMITTY1290
  • 6 POSTS
Okay. So, I tested camshaft sensor and it get 5 volt but I fluctuates sometimes between 2.9 and 5.0v is my connector bad or is it the ECU? thank you in advance.
Sep 14, 2023 at 8:33 AM
DSMITTY1290
  • 6 POSTS
Also, should I be getting battery power from the other terminal and if so, could that be my issue? Because I'm not getting but 4v.
Sep 14, 2023 at 8:54 AM
DSMITTY1290
  • 6 POSTS
Hey back again, it's going straight to engine disable mode I start the car it jumps to about 1,500-2,000 RPMs then engine disabled shut down.
Sep 15, 2023 at 1:10 AM
  • 55,710 POSTS
When you are monitoring the 5 volt reference unplug the other sensor to see if it jumps if not it sounds like the PCM is bad, you can get a preprogrammed unit by searching Google or Ebay.
Sep 15, 2023 at 4:20 AM
DSMITTY1290
  • 6 POSTS
Thank you. I'll have to order the new one, but I will keep you updated once it's replaced.
Sep 15, 2023 at 7:46 AM
  • 55,710 POSTS
Please do!
Sep 18, 2023 at 3:13 AM
