Been getting a code for Idle Air control circuit low- P0508 on my vehicle. IAC was changed and rewired along with the PCM being changed, throttle body was cleaned and changed TPS. Code was cleared ran great for 5 days then code reappeared along with a whistling noise and it doesn’t want to start sometimes so I have to disconnect battery and it will start after. Running out of options because after all that it still isn’t fixed. Need help as I can’t afford to take it to a mechanic. please help!
Nov 22, 2019 at 2:11 AM
