Code p0507?
146,900 MILES • 3.7L • 6 CYL • 2WD • AUTOMATIC
FRANCISCO_1220
My truck recently showed a code p0507 Idle control system/motor RPM higher than normal.
I’m aware that the ACV is in the throttle body as it is electric so I replaced the throttle body and re learned it and the code popped back up less than 10 miles. what can be the problem and how can I fix it? thank you
May 2, 2025 at 4:45 AM
MECHTRIX
  • 573 POSTS
Sounds like its either a vacuum leak or a clogged air control valve.
May 2, 2025 at 11:37 AM
MECHTRIX
  • 573 POSTS
But since you changed the idle air control valve when you got a new throttle body its most likely a vacuumed leak check all lines hoses parting line areas where a leak can occure. good luck
May 2, 2025 at 11:47 AM
FRANCISCO_1220
I don’t think it as an air control valve as the throttle body is electrical and I thought about the same thing a vacuum leak the throttle body is new, and it still threw the code.
May 2, 2025 at 11:48 AM
FRANCISCO_1220
Thank you Mechtrix. I will inspect the hoses well and let you know if that was the issue. thank you
May 2, 2025 at 6:35 PM
MECHTRIX
  • 573 POSTS
Yes.check for leaks but also check the IAC valve since the code indicates that the problem is there. got to find it i believe on this vehicle it is held in by one bolt and pulls straight out and has a 2-wire plug.
May 3, 2025 at 6:48 AM
MECHTRIX
  • 573 POSTS
Should be right near or on the throttle body.
May 3, 2025 at 6:49 AM
MECHTRIX
  • 573 POSTS
If you pull it out you can sometimes clean them with an old toothbrush and some spray cleaner, but i usually just replace them since theyre usually pretty cheap. hope this helps
May 3, 2025 at 7:06 AM
