can i use a little Tecron to clean in the hoses to EVAP solenoid?
Sep 20, 2019 at 2:00 AM
BMDOUBLE
✓Experienced Mechanic
The techron I'm thinking of is the fuel injector cleaner, do you mean mercon? like for lubrication? The hoses are meant to withstand fuel contamination, but I usually use a silicone spray or wd-40.
Sep 20, 2019 at 3:16 AM
DAVEA06
MEMBER
I needed to make sure that the hoses in and out of the EVAP solenoid were clean before changing it. Used a little bit of rubbing alcohol. That should have been a no brainer. All's fine. Just didn't want to buy brake cleaner that would sit on the shelf for a few years. Thanks for the response.
