Codes P0430 and 61-11?
158,800 MILES • 3.6L • V6 • 2WD • AUTOMATIC
CBISWAS16
  • 5 POSTS
Someone said I need to replace the catalytic converter. Looking for your suggestions.
May 12, 2023 at 12:37 AM
  • 110,248 POSTS
The 61-11 is related to the vehicle stability assist. That isn't tied to the P0430. That code indicates the bank two catalytic converter is operating below the threshold.
Does, that mean it needs to be replaced? Oftentimes, it does. However, before replacing the converter, try this.
Fill the tank with premium fuel and get a good quality fuel injector cleaner. Drive the vehicle for approximately 50 to 100 miles then clear the code. See if the code comes back.
Let me know if that helps.
joe
May 12, 2023 at 2:15 PM
CBISWAS16
  • 5 POSTS
Hey Joe, thanks for your feedback. Could you please suggest to me the best way to use the fuel injector cleaner?
Close to empty the tank > Injector> premium fuel full tank??
Thanks,
Chinmay
May 14, 2023 at 10:32 PM
  • 110,248 POSTS
There are a lot of different manufacturers that make it. I attached a pic below of an example that has helped others in the past.
This will be added to the fuel system. The directions are on the product.
See pic below.
May 15, 2023 at 12:03 PM
CBISWAS16
  • 5 POSTS
How can I clear the code after fill tank with premium fuel and injector cleaner?
I have tried but engine light still there.
"Fill the tank with premium fuel and get a good quality fuel injector cleaner. Drive the vehicle for approximately 50 to 100 miles then clear the code. See if the code comes back."
Looking for your help.
Thanks
May 16, 2023 at 1:40 PM
  • 110,248 POSTS
You can clear the code with a scan tool. If you don't have access to one, disconnect the negative battery terminal for about 10 minutes. It should clear.
May 16, 2023 at 2:12 PM
CBISWAS16
  • 5 POSTS
I have cleared the code but hard luck. It's back again. Looking for your suggestions.
May 21, 2023 at 10:49 PM
  • 110,248 POSTS
I had hoped that would help. At this point, the converter is likely faulty, and needs to be replaced. If you want, take a look at this link. It explains how to test a converter. You will need an infrared thermometer to check converter temperatures. Take a look.
https://www.2carpros.com/articles/how-to-test-a-catalytic-converter
Let me know what you find or what I can do to help.
May 22, 2023 at 12:17 PM
